Need to make a simus movement!
Do you mean a sine wave, like the attached? If so I have some RAPID code that you could use.
Benteler Maschinenbau CZ0
I believe that is not a very hard thing to do.Theoretically, you are moving along a straight line, just moving up and down (left and right, whatever you wish) along that line.You should define how many points you can put in between of the source- and destinationpositions.When you know the amount of positions you gotta move to in between of the source and destination, you know the amount of sine waves (that is X points / 2, since one wave = 2 points. One low point and a high point).After this, you need to know the distance of the original line you move between, then you can calculate at what distances you want the points to be. Also, the height of one wave (from the original line to the top) must be known, then you can create a position.You can also add support for rotation around the Z axis, which will let you move your robot in a sine wave which isn't up and down, but maybe left and right along a line.Unfortunately I don't have any code to send you, but if this doesn't help you i might be able to write some in my free time.Greetings,B_Baan0
