S4C+ Will not boot up
I have an M2000 S4C+ that will not boot up. It says teach pendant communication lost.
Here are my LED's
On the Power Supply I am green.
On the DSQC 509
En: Nothing
MS: Green
NS: Nothing
DSQC 504
Nothing
DSQC 513
Nothing
CPU
PWR: Green
HDD: Nothing
Status: Solid Red
What do I need to hook a terminal to it, or is there somewhere else to start.
Any help you can provide would be greatly appriciated.
Hello,,
LEDs status say the Computer system is in abnormal and Communication doesn't work at all. Solid Red means O.S loading from Flash disk.
The reason might be following two things.
1. O.S is corrupted.
2. Flash disk is broken.
If you want to monitor in depth situation, Use "MC console mode"(Connecting hyper terminal to S4Cplus via Serial cable.)
Regards,
I have made the cable and hooked it to MC/Concole connection on the computer.
My cable is as follows:
ABB Laptop
MC/C. Com1
2---------3
3---------2
5---------5
I have tried many different settings for my hyper terminal with no success. I can not find those setting in my manuals, would anyone have them handy.
I am looking for:
baud rate: (bits per second)
Data bits
Parity
Stop bits
Flow control
Again thank you very much for all of your help.
Edward Grabow0 -
I think I got it but nothing comes up. I have pulled the mass storage DSQC564A 64MB memory. There is a jumper setting on it. Is there a way to reset this incase it is corrupted and not destroyed?Edward Grabow0
Took Your advice and replaced the Flash disk and everything works again. THANK YOU!!!!Edward Grabow0
hellowe have a abb irb6400 m98 robot with control software s4 the system is empty and requires installathin of controller software an system disply this message "please insert key disk"who can help us in this case???becase of we dont have key disk.and my email is " ismaelshahi@gmail.com"shahi0
- 858 RAPID Programming
