PCSDK ReadUIInstruction() fails
DanS
Several machines in production, all using PCSDK will eventually fault with this error:
An exception has occurred.
Message: Attempt to access the method failed.
Source: ABB.Robotics.Adapters.IRC5
StackTrace: at Adapters.Rapid.ReadUIInstruction(String taskName, String stackUrl)
at ABB.Robotics.Controllers.Internal.UIInstruction.ReadUIInstruction(String taskName, String stackUrl)
InnerException:
An I-start will resolve the issues, but it will occur again in time. How can I go about resolving this issue? Any help/advice would be appreciated.
Thanks,
Dan.
