Synchronization and Local Targets
Vinnie
RobotStudio doesn't support local targets unfortunately, all targets are treated as globally in RS. The issue has been discussed but it would have too much of a negative impact on the gui of RS to change this limitation.
Actually, targets can be declared locally in two ways: either by declaring them as LOCAL CONST in the MODULE header or by declaring them as CONST in a PROC. If you declare your targets in the procedure - they won't be synchronized at all. If you declare the targets in the module header they will be synchronized but two locally declared targets with the same name will not be distinguished between in RS.
I would recommend you to copy/paste all your declarations to the module headers and set them to LOCAL CONST - then synchronize ONE path at the time into RS and use the Rename targets functionality in RS for each path synchronized - to prevent duplicated targetnames in RS.
_____________________________________
Peter Fransson, ABB Automation Tech.
Peter Fransson
Support Engineer
ABB Automation Technologies
ATMA/RO/AIS0
- 400 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 345 IRC5
- 73 OmniCore
- 844 RAPID Programming
- 20 AppStudio
- 108 Collaborative Robots
