robot articulation(motor) angle
hello,
Please is it possible to assign angle value, in degree, of each robot motor (articulation)?
thanks for any help
  • You didn't specify where you wanted this done. But yes...
    ... if you meant the mechanism model in RobotStudio then in the [Layout] browser, right click the mechanism and in the context menu select [Mechanism Joint Jog] .
    Then you can, by joint, either drag the bar, or, with a joint selected use the number keys to enter a specific number of degrees.
    ...if you instead meant during motion then the RAPID command you are looking for is MoveAbsJ
    http://developercenter.robotstudio.com:80/Index.aspx?DevCenter=DevCenterManualStore&OpenDocument&Url=../RapidIFDTechRefManual/doc93.html
    like this:
    MODULE Module1
         CONST jointtarget JointTarget_1:=[[5,10,15,20,25,30],[9E9,9E9,9E9,9E9,9E9,9E9]];
        PROC Path_10()
            MoveAbsJ JointTarget_1,v1000,z100,tool0\WObj:=wobj0;
    ENDMODULE
    If you meant in some other context then please specify further.
  • Thanks for your response, actually mean using "RAPID" instructions..
    Probably "moveabsj" will help..
    For example if i want to rotate a "target" in "global" without using : select target-->mouse right clic-->rotate?but using RAPID instructions.
    Sorry for my english and by the way what shall i do to change the RS language from French to English without re-installing it ?
  • Is there any equivalent to "RelTool (Point Dx Dy Dz [\Rx] [\Ry] [\Rz])"  but [\RX]... will be rotations along the robot base axis ?
  • For changing the language, i found it. It is simple : file-->options-->appearance-->select application language
