Robot Colour
Neily03
I know this is a bit trivial but when I build a station the robot (IRB5400) i'm given is the new Graphite Grey, but our robots are Orange, is there a way to set the robot to orange? I'm using 5.61.01.01 if that makes a difference.....
If you click on the "Browse for Library" button and locate the directory where the robots are installed (typically C:\Program Files (x86)\ABB Industrial IT\Robotics IT\RobotStudio 5.60\ABB Library\Robots) you will find all the orange ones as well. The ones without a "_G" in the name are usually orange.
I guess you could also recolor an existing robot in the station, but you will have to do it part by part. Select "Graphics Tools", then click on the "Edit" tab to the right. If you have something in your station with the correct orange color (just temporarily load another orange robot) you can select "Pick material" and then "paint" it on your gray robot. Be sure to set selection mode to part though.
/Anders
Anders Ekelund
Architect, RobotStudio
ABB0 -
Excellent, thanks Anders.
