Booting Initialization Message
Hello!
I have installed three abb robots, one IRB 140, one IRB 1600 and one FlexPicker, these robots were about 6 months without operating. Today I tried to use the robots, but in the teachpendant a message appears , "booting initialization", and is stopped at this point. What can this be?
Thanks.
J.Frantz
Thanks.
J.Frantz
Have you tried rebooting the teach pendant? There is a button on the back in a hole you can push with a small tool of some sort. Most likely a teach pendant issue. If you can get to the 'connecting to robot controller' screen but nothing from there, check the ethernet connection to the PC in the cabinet.0
You could try restoring a disk image back onto the CF card and download the latest project.Do not fear to be eccentric in opinion, for every opinion now accepted was once eccentric..0
