Task MAIN: Fatal runtime error
hi
I get this message when executing the path with VC and Collision set.
What does it meen???
Kent zibrandtsen
Hardi International A/S
Denmark
  • Hi,
    That message indicates that something is wrong in your rapid program. Open the TeachPendant or ProgramMaker and control that you don't have any syntax or reference errors.
    ABB Robotics
  • Sometimes,You should shut down the VC and restart it.
    It will work again.
  • Hi
    I have looked in program maker and there are no syntax errors.i have also shut down and restartet vc but still with the same result.
    it seems that it is not always at the same place this error pops up.
    Kent zibrandtsen
    Denmark
