Loading existing modules to Station, case sensitive....
Does anyone else have problem where you can't load modules to the station if the file extension (.mod) is in capitals? When I try to load one (through the painting powerpack) with the extension .MOD nothing happens but if I change the extension to .mod it loads fine......
  • <p>I have a similar issue...</p><p>I cannot load any additional .MODS after 40</p><p>I can load any other type of file of any size... </p><p>If I delete one of the current mods I can then add the new one.</p>
