communicate variables among multiple robots
Is there any way to communicate variables among multiple robots in Rapid with the same controller?
Thank you
  • Hello,
    If you have multiple robots on 1 controller, you have 1 task per robot.
    You have to declare your variable in each task with the same name. but you can only declare a value in 1 task.
    exemple:
    T_ROB1: PERS bool b_test:=False;
                    PERS num n_test:=5;
    T_ROB2: PERS bool b_test;
                    PERS num n_test;
    if now you change b_test in T_ROB1, it also change in T_ROB2 and vice versa.
    BR
    Peter
  • Peter1 said:
    exemple:
                    PERS num n_test:=5;
                    PERS num n_test;
    BR
    Peter
    Thank you very much, you´ve been very helpful
