About GripLoad Loaddata;
Hallo everyone,
i have a Problem. I define an Loaddata Array  als PERS.
PERS loaddata Muffe_Load{47}:=[[03.62, [0, 0, 0.4],[1, 0, 0, 0], 0, 0, 0],
[04.66, [0, 0, 0.4],[1, 0, 0, 0], 0, 0, 0], .......];
But it is not working with Gripload.
PROC GreiferClose()
Reset DO10_0GripperClose;
Set DO10_1GripperOpen;
WaitTime 0.5;
GripLoad Muffe_Load{12};
Everytime Shows the follow Message:
41442: Reference Error
Description
Task: T_ROB1The reference in argument Load is not an entire persistent variable. Program Ref. /VenConfig/Greiferspannen/GripLoad/96
Actions
It is not possible to use record component or array element in arg. Load . It is only possible to use entire persistent variables for Tool, WObj or Load in any motion instruction.
Thanks
  • Hello,
    Did you forget to put TASK before creating the loaddata? as in:
    TASK PERS loaddata Muffe_Load{47}:=[[03.62, [0, 0, 0.4],[1, 0, 0, 0], 0, 0, 0],
    This works for me...
    I got this:
    TASK PERS loaddata LoadGripper{2} := [[0.001, [0, 0, 0.001],[1, 0, 0, 0], 0, 0, 0] , [0.001, [0, 0, 0.001],[1, 0, 0, 0], 0, 0, 0]];
    GripLoad L0adGripper{1};
    This works for me
  • Hallo B_Baan,
    Thank U for your Answer;
    I have copy your code. But It does not work for me. It is same error.
    Now i define a between-pers loaddata .  It called  "current_load"
    Verytime i update this data from my Loaddata-array.  It worked!
    PERS loaddata current_load:=[5.23, [0, 0, 0.4],[1, 0, 0, 0], 0, 0, 0];
    Pers num MuffeNrCurrent:=0;
    Proc Gripperclose()........MuffeNrCurrent:=DnumToNum (GInputDnum(gi17_22MuffeNr));
    current_load:=Muffe_Load{MuffeNrCurrent};
    GripLoad current_load;
    endproc
