Creating a real time light drawing application
Dear reader,
I'm looking into the possibilities to create a real time drawing application. I'm going to attach
an LED (or some other light) to the tcp of a ABB IRB 140, in a dark room and record the
light in a custom application that grabs images from a webcam. This will result in drawings
that look something like this:
I'm not a experienced RAPID programmer but have plenty of experience in languages like
C, C++, etc.. And after reading the RAPID manual and playing with Robot Studio I can get around the
basics for now.  Though because of my lack of experience I want to ask here what kind of options I
have to create something like this.  It would be ideal (if possible) when the ABB could move to
target points I send over TCP/IP in real time and that I can work w/o a work object so I can easily
move around in the area that the arm can reach (I don't know yet how to get this area in which
I can freely move around and if I can get into problems with configurations).
If possible I would start a listening socket on the controller to which I sent commands from my
other application that tells the ABB to start moving to make these light paintings. A command could
be something like "move to this point", "turn lamp I/O port high/low" etc.. I'm curious if this approach is
possible what kind of performance I may get from the ABB. And if I need to think about any memory and/or
performance limitations.
I understand I'm asking a lot, though I hope I can get some more information so I can start working on
an application using these fantastic robots.
Thanks
pollux
