IRC5 DeviceNet - PPC - Byte Swap
Options
I have a IRC5 running Robotware 5.07.1030 with an internal slave that is configured and connected to a Rexroth PPC controller. The problem I'm having is the input image is byte swapped.
Are there any Dnet configuration settings to correct the byte swap?
The input image is being used as GI and assigned to num values. Are there any work arounds in rapid to byte swap?
Kevin C
Kevin Crosby - Propack
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 405 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 734 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
