How to break out of WHILE ?
When I have a simple while loop, how can I break out of it? (e.g. break in C/C++).
p
  • You break out of while when the conditions on top are not met
  • Hi pavpav,
    Thanks I thought so but will hoping RAPID supported a C-ish `break`.  But if that's not possible I'll add it to the while condition.
    p.
  • The closest I can think of is the RETURN statement that will exit the current routine. That might work if you put your WHILE statement in a dedicated routine.
    ABB
  • Hey Pollux,
    You can also use the GOTO statement like this:
    MODULE WhileLoop
        VAR num count := 0;
        PROC TestWhileloop()
            WHILE TRUE DO
                IF count > 5 THEN
                    GOTO nextPart;
                ENDIF
                Incr count;
            ENDWHILE
            nextPart:
            TPWrite "Out of while loop";
            Stop;
    ENDMODULE
    hope it helps,
    Lars
    Lars Glud
    Danrob A/S
  • Ah thanks guys for all the possible solutions!
  • AlexK
    AlexK ✭✭
    edited November 2014
    But then this would do the same with less code and without the use of GOTO which I ware thought never to use when I started programming ABB robots.
    MODULE WhileLoop
        VAR num count := 0;
            WHILE count <= 5 DO
                Incr count;
            ENDWHILE
            Stop;
    ENDMODULE
    Best regards
    Alexander Källberg
