Separating pieces of a body.
Robin_S
Hi!
I was wondering if there is any way to remove the pieces of a body in RobotStudio?
I don't mean a body suchs as one composed of multiple small bodies combined to a bigger one, but a CAD-file that is all bodies as one and the same?
So instead of removing the entire machine I can remove only the door?
Is there a way to do that, or do I have to get the bodies "decomposed" before it's possible to take handles and doors and such away?
I've tried making them invisible, but every time I open the cell again they're all visible again and it takes a lot of time to make them invisible again.
I really need a solution of this problem..
/Robin_S
no not really.Buy a workaround could be to invert the surface under graphic appearance->properties. then select the surface as you did when you made them invisible, and then invert the surface.0
It looked like it worked at first, but the items are still visible from the other side, which doesn't really help me that much since I need them completely gone.However, when they have been inverted, they don't appear when re-opening the station. And that's positive at least!
Thanks for your help anyways, shows us that the Dane isn't all barbaric and our eternal enemy
(Just to make clear, you're still not getting Skåne!)0 -
You can create an object with same size as the door and place it over the door, then u subtract the object you created from the machine with the subtract tool0
