Virtual FlexPendant white render issue
Hi!
I have just got a strange thing with my Virtual FlexPendant. When i start it it turns white. The "ABB" and "Operator Window" button is shown.
You can click on them. You can tell he go to the right menu. But you cant see it, its all white.
It all started when i connected my tablet as a secound monitor. Wanted to run Virtual FlexPendant on it. Virtual FlexPendant did crash and after that i cant see it any more.
I guest it some how try to render it on a non exicting screen. There for the white screen in VFP. Is there a way to restart the VFP?
Its on all project. Even if create a new one, i get the same white screen.
If i press any right side button I get a .Net Error dialogbox with the following error message:
<code>
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
RobVCTAFWrapper.TAFException: Exception of type 'RobVCTAFWrapper.TAFException' was thrown.
   at RobVCTAFWrapper.SingleMdiVGTPU.PressKey(RobVCVGTPUKeytype keytype)
   at VirtualFlexPendant.CoolForm.btnHard_MouseDown(Object sender, MouseEventArgs e)
   at System.Windows.Forms.Control.OnMouseDown(MouseEventArgs e)
   at System.Windows.Forms.ButtonBase.OnMouseDown(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.18444 built by: FX451RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Virtual FlexPendant
    Assembly Version: 5.60.5731.84
    Win32 Version: 5.60.5731.84
    CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.60/Bin/VFP/Virtual%20FlexPendant.exe
    Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
    Win32 Version: 4.0.30319.34238 built by: FX452RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
RobotStudio.Services.RobApi
    CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.60/Bin/RobotStudio.Services.RobApi.dll
RobVCTAFWrapper
    Assembly Version: 5.60.84.0
    Win32 Version: 5.60.84.0
    CodeBase: file:///C:/Program%20Files%20(x86)/ABB%20Industrial%20IT/Robotics%20IT/RobotStudio%205.60/Bin/VFP/RobVCTAFWrapper.DLL
System.Xml
    Win32 Version: 4.0.30319.34234 built by: FX452RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
ABB.Robotics.RobAPI.Interop.RobCtrlInfoLib
    Assembly Version: 1.0.0.0
    Win32 Version: RW 5.60.0084.00
    CodeBase: file:///C:/Windows/assembly/GAC_32/ABB.Robotics.RobAPI.Interop.RobCtrlInfoLib/1.0.0.0__1da709b7d1f14b7b/ABB.Robotics.RobAPI.Interop.RobCtrlInfoLib.dll
Dcl.Base
    Assembly Version: 5.60.1001.0
    Win32 Version: 5.60.1001.0
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/Dcl.Base.dll
ABB.Robotics
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/ABB.Robotics.DLL
ABB.Robotics.RobAPI.Interop.RobDataLib
    CodeBase: file:///C:/Windows/assembly/GAC_32/ABB.Robotics.RobAPI.Interop.RobDataLib/1.0.0.0__1da709b7d1f14b7b/ABB.Robotics.RobAPI.Interop.RobDataLib.dll
System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
TAF
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/Taf.exe
Taf.BaseInternal
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/Taf.BaseInternal.DLL
Taf.Reflector
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/Taf.Reflector.DLL
Taf.ComponentManager
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/Taf.ComponentManager.DLL
Taf.Master
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/Taf.Master.DLL
ABB.Robotics.Tps.Taf
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/ABB.Robotics.Tps.Taf.DLL
ABB.Robotics.Taf.Base
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/ABB.Robotics.Taf.Base.DLL
TpsAppRootCtrl
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/TpsAppRootCtrl.dll
ABB.Robotics.Tps.Internal
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/ABB.Robotics.Tps.Internal.dll
TpsABBPanel
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/TpsABBPanel.dll
TafFormLauncher
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/TafFormLauncher.DLL
ABB.Robotics.Tps.Windows.Forms
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/ABB.Robotics.Tps.Windows.Forms.DLL
Dcl.Controller
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/Dcl.Controller.DLL
ABB.Robotics.Tps.Resources
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/ABB.Robotics.Tps.Resources.DLL
TpsTexts
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/language/en/tps/TpsTexts.dll
Dcl.FileSystem
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/Dcl.FileSystem.DLL
TpsCtrlStatusBar
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/TpsCtrlStatusBar.dll
ABB.Robotics.GTPU.Windows.Forms
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/ABB.Robotics.GTPU.Windows.Forms.DLL
Dcl.EventLog
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/Dcl.EventLog.DLL
TpsCtrlQuickSet
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/TpsCtrlQuickSet.dll
Dcl.Motion
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/Dcl.Motion.DLL
Tps.SystemSettings
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/Tps.SystemSettings.DLL
Dcl.EventServer
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/Dcl.EventServer.DLL
TpsViewUAS
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/TpsViewUAS.DLL
Dcl.DeviceServer
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/Dcl.DeviceServer.DLL
Dcl.Rapid
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/Dcl.Rapid.DLL
Dcl.Jogging
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/Dcl.Jogging.DLL
Dcl.Tpx
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/Dcl.Tpx.DLL
Dcl.CmdServer
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/Dcl.CmdServer.DLL
Dcl.ObjectBrowser
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/Dcl.ObjectBrowser.DLL
Dcl.SystemInfo
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/Dcl.SystemInfo.DLL
Dcl.Data
    CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/ABB%20INDUSTRIAL%20IT/ROBOTICS%20IT/MEDIAPOOL/ROBOTWARE_5.60.1001/vcbin/Dcl.Data.DLL
System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
</code>
