Variable accessible in multitasking
ko414du4
I am using multitasking and there are currently 2 tasks in my RAPID code. How can I share a variable declared in 1 task and use it in another? I thought PERS var declared in a module is global but I got Reference Error when I applied the change. Can anyone help please?
Thank you.
Best Answer
You have to declare the variable in both tasks. For instance:task 1:PERS bool testBool:=TRUE;task 2:PERS bool testBool;5
I had the same problem. Thanks for de solution.
But I have other problem about global variables.
I can't share a variable type SPEEDDATA in two tasks.
I always get a Rapid error.
I have used this code:
Example 1:task 1:PERS speeddata speed:=V1000;task 2:PERS speeddata speed;
Does someone help me?
Is possible to do that?
Thanks a lot
Hi V1000 is a constant variable declared in the system so you need to
either declare your variable with values or assing them later in the program
Per Svensson
Consat Engineering1 -
Thank you.
I am going to test it...
- 40 AppStudio
