Offsetting TCP of a tool
bob865
Hello all,<br><br>I'm hoping I can get some help with a project I'm working on. What I need to do is offset the TCP of a tool. I've looked through some old threads and can't find an answer. I have a tool, but the working direction of the tool is not in line with axis six. It is off at roughly 45 degrees. I need to move the tcp along the Z axis (working direction) of the tool, but because it is at an angle to axis 6 of the robot, I can't simply change the Z value in the tooldata. A move in the Z direction of the tool would end up being a slight change in X, Y, and Z of the tool. How can I figure out what the new values would be? I need to know how to calculate this mathematically. Ultimately I will be building a function/routine to do this calculation on the fly so if there is already a function built that does this arithmetic that would be ideal.<br><br>The application that I'm working on is a non-robot version of the MeasureWearL command for measuring the tip wear on weld guns. What I need to be able to do is after I determine how much of the tip has been ground off during dress, say 2mm, I need to be able to update the TCP of the weld gun by the same 2mm in the Z (working direction) of the gun.<br><br>Any help and or ideas are appreciated.<br><br>Thanks.<br>
Hi,<br><br>for the calculation of the tool you can use the function "PoseMult".<br><br>You have to use the pose from the orginal tool (tFrame) and you define the a new pose which contains the translation and the rotation (quaternion).<br><br>See following example to move the TCP in Z-direction:<br><br> <br><br> !pose for the calculation<br> VAR pose pseFrame:=0,0,0],[1,0,0,0;<br><br> !Translation in Z-Direction<br> VAR nDZ:=20;<br><br> !Get the data of the old tool<br> tNewTool:=tMyTool<br><br> !assign translation for z-direction to a pose<br> pseFrame.trans.z:=nDz;<br><br> !Calculate translated tool<br> tNewTool.tframe:=PoseMult(tMyTool.tframe, pseFrame);<br><br> <br>BR<br><br>Micky<br>1
That did it. Thank you.<br>0
