Mini Task to Simulate a path RobotStudio
<font face="Arial, Verdana"><span style="font-size: 10pt; line-height: normal;">Hi,</span></font><div style="font-family: Arial, Verdana; font-size: 10pt; font-style: normal; font-variant: normal; font-weight: normal; line-height: normal;">It's the first time that I try to create a simulation path to move my robot in 3d robotstudio view.</div><div style="font-family: Arial, Verdana; font-size: 10pt; font-style: normal; font-variant: normal; font-weight: normal; line-height: normal;">My first step is to move programmatically the robot tool around in a square path. </div><div style="font-family: Arial, Verdana; font-size: 10pt; font-style: normal; font-variant: normal; font-weight: normal; line-height: normal;">Only an easy 3d simulation to move the robot with RS SDK code.</div><div style="font-family: Arial, Verdana; font-size: 10pt; font-style: normal; font-variant: normal; font-weight: normal; line-height: normal;">It's important for me because I have to make an easy 3d simulation as soon as possible.</div><div><font face="Arial, Verdana"><span style="font-size: 10pt; line-height: normal;">Are there some tutorial task that show how to do this? </span><span style="font-size: 13px; line-height: normal;">Does anyone help me?</span></font></div><div><font face="Arial, Verdana"><span style="font-size: 13px; line-height: normal;">Thanks in advance.</span></font><br></div>
  •  I found something about it:
    (this example is using a set of RsTarget)
    n-->number of the element
    RawPath[] path = new RawPath[n];
    RsPathProcedure myPath = new RsPathProcedure("myPath");
    RsMoveInstruction myMove = new RsMoveInstruction[n];
    RsTarget[] myRsTarget = new RsTarget[n];
    RsRobTarget[] myRobTarget = new RsRobTarget[n];
    mystation.ActiveTask.PathProcedures.Add(_myPath);
    for(int i = 0; i < n; ++i){
    //my function that creates a move where I passed: starting position of the path line, its orientation and an incremental index
            myMove[i] = CreateMove(newVector3(1,2,3), new Vector3(0, 180, 0), i);
            myPath.Instructions.Add(_myMove[i]);
    RsMoveInstruction CreateMove(Vector3 position, Vector3 orientationXY, int index)
     RsRobTarget robTarget = new RsRobTarget();
     // Set the position and rotation of the
    RobTarget.
    robTarget.Frame.X = position.x;
    robTarget.Frame.Y = position.y;
    robTarget.Frame.Z = position.z;
    robTarget.Frame.RX = ABB.Robotics.Math.Globals.DegToRad(orientationXY.x);
    robTarget.Frame.RY = ABB.Robotics.Math.Globals.DegToRad(orientationXY.y);
    robTarget.Frame.RZ = ABB.Robotics.Math.Globals.DegToRad(orientationXY.z);
    // Add the RobTarget to the DataDeclarations of the ActiveTask.
    mystation.ActiveTask.DataDeclarations.Add(robTarget);
    // Create an RsTarget for the RobTarget, to give it a graphical representation and use it to get configs.
    RsTarget rsTarget = new RsTarget(_station.ActiveTask.ActiveWorkObject, robTarget);
    rsTarget.Name = robTarget.Name;
      // Add it to the ActiveTask. mystation.ActiveTask.Targets.Add(rsTarget);
    myRsTarget[index] = rsTarget;
    myRobTarget[index] = robTarget;
      return new RsMoveInstruction(
      mystation.ActiveTask,
    "Move",
    "Default",
    MotionType.Linear,
    mystation.ActiveTask.ActiveWorkObject.Name,
    robTarget.Name,
    mystation.ActiveTask.ActiveTool.Name);
    to execute the path call this --> myPath.MoveAlong();
