User interface related to 4k monitors or high-res
Recently, 4k monitors are being used more frequent and some issues is worth taken not of. In RS some issues can be notices regarding for example some graphic icons. If you know what to look for and where they are, fine, but otherwise it is a guess... Also, the help window has a text which you have to read from close distance to be able to get the message. I have a large screen (32 inch), but now I have seen 24 inch with 4K and with sigh a high res it will be even small text.<br>This issue is not unique for RS, but feel I need to update you on this.<br>
  • Johannes Weiman
    edited February 2015
    Hi Gunnar,
    We have put some effort into this for RS 6.0 and it should look ok at up to 200% DPI.
    Feel free to post screenshots of remaining issues and we will take a look at it :)
    Regards, Johannes
    Johannes Weiman
    Software Engineer
    RobotStudio Team, ABB Robotics
