Motion Supervision Tune Values.
If you have the Collision Detection option you can change the sensitivity of the Motion Supervision using the MotionSup instruction. The value of the MotionSup can go from 0 to 300. The larger the number the less sensitive to collisions. But this is a percentage of the value in Motion System Parameter / Path Collision Detection Level.
The Path Collision Detection Level is the sensitivity of the robot to collisions without the Collision Detection option. It is also the base value for the MotionSup instruction.
So by default, the robot will come with a Path Collision Detection Level of 100. The value in the MotionSup instruction will be a percentage of the 100 level. If you modify the Path Collision Detection Level to 150, making the normal collision detection less sensitive, the MotionSup instruction will be a percentage of the 150 level.
There is no way in RAPID to get the current settings. You need to keep track. Perhaps use a persistant num data to set always set the TuneValue in the MotionSup instruction.
