External Axis Wizard And Multiple Joints Conrolled by One Motor
tnixon
I have a mechanism that has three external axes. One of the external axes is controlling two fixtures that are interconnected, call them joints 3 and 4. I added a dependency between joints 3 and 4, and they seem to work properly using mechanism joint jog. The External Axis Wizard wants to add four motors to the mechanism because there are four joints. How do I set this up properly?
Thanks,
Ted
Just an idea, when using External Axis Wizard use a temp mech with one joint. After the system is built change to your real mech with two joints.
BR / Henrik
Kga Offline Center www.kgaofflinecenter.se
Offlineprogramming and simulation in RobotStudio and ArcWeld PowerPac0
- 858 RAPID Programming
