Set priorities between robot joints!
I'm trying to find a solution to tell RobotStudio that I want to have the 6th joint of my robot used only in the case where it is not possible to do it without?
Any ideas?
Tibor Gyorgy
  • You mean when robot is going through singularity? If so i guess you should read something about RAPID SingArea command
  • Not only when going out trough singularities; I have defined targets which can be easily reached by the robot when the 6th joint also is used but I want to reach them keeping the 6th joint at 0° (not always possible but in most of the cases). I red something about SingArea, I think it can be a solution. Thank you!
