Multitasking - Recognize "PP to main" from non motion task (Button activated AND SystemInput)?
Is it possible to recognize that the program pointer in the motion task was set to main, from a non motion multitask which is always running?
No matter if it was set to main manually or with a system input.
I know that ther is this command: "IsStopStateEvent (\PPToMain)"
But i cannot specify in which task the event should be monitored. It only works in the task were it was called.
