Placing a robot on a slope
We want to place an IRB4600 robot on a platform which has an angle of 20 degrees. I want to know if it is ok for the robot to work on such slope. I looked at the documentation and could not find anything yet. Is there any documantation I can check that if it is ok or not?
Thanks for your time
Best Answer
In the manual it say 19deg but you should get in contact with your ABB salesmen to get the correct answer for this robotPer Svensson
Consat Engineering5
As Per points out, you must get a confirmation from your local ABB office. Otherwise, I suspect the warranty might be violated if anything should happen to the robot.
/Henrik
ABB1
