Is it possible to write power consumption recorded by Signal Analyzer in a logfile?
I am trying to decrease the power consumption of robots simulated by RobotStudio 6.01 SP1 (Version 6.01.6426.0123). It is possible to automatically write a logfile which includes the messured time by the clock function (see code below). It would be a great improvement to my work if I have the possibilty to write e.g. the max value of the power consumption in the same logfile. The value is recorded by the signal analyer tool (I can export it from there in an other Excel table) but I can't find the order to get this value directly via the rapid code in the manuals.
Please let me know if there is a soultion to this problem or if I should specify the question!
Thank you
- 858 RAPID Programming
