how to assign data to pos through external files
WuYue
I am reading the coordinate [x,y,z] from external txt file into an array. My questions are:
1) how to assign the array to pos type? for example, I have input=[1,2,3], and I define VAR pos position; can I use position :=input?
2) as my position is a VAR (variable) already. When I define
VAR pos position;
VAR num input{3};
VAR robtarget Target_20:=[position,[0.499999903,0,0.86602546,0],[0,0,0,0],[9E9,9E9,9E9,9E9,9E9,9E9]];
the program has this error: the expression position is not a constant expression. How can I solve this problem?
Thanks!
Hi this may he PROC myTest() VAR pos myPos; VAR num myPosArray{3}:=[1,2,3]; VAR robtarget myTarget; myPos.x:=myPosArray{1}; myPos.y:=myPosArray{2}; myPos.z:=myPosArray{3}; myTarget.trans:=myPos; ENDPROCPer Svensson
Consat Engineering0 -
Hi, PerSvensson, Thanks for your reply! It works!0
