Configuration of StantAlone Controller
GAC_MEF_Roth
Hi together,
I have no experiences using the StandAlone Controller. So I made some tests but till now no real success and I hope that maybe someone could help to solve my problems.
I want to realize a simple Scara-kinematic and control this robot with the IRC5. The Scara-Robot has to rotational axis - please see a simple picture of the robot in the attached file.
Based on the information of the manual I chose a kinematic model and here my problems starts. I don't know if it is correct to use the two axis doppin feeder - maybe someone could tell me if the chosen model is correct or not?
Anyhow I tried to configure my system with my choice independently if it is correct or not. But just as I added the virtual controller to my station I got one system-error after another. I put my MOC-file as well in to this post. Do I need to load other *.cfgs to get it running. I also tried to compare MOC-files from standard ABB-robots with the MOC-file of the SAC, but the motor definitions aso are completely different. Maybe someone could give an advise how to get my system running.
if a Pack&Go is helpful, I also can post it.
KR/
Michael
