Track and robot move in opposite direction
Folks, in base coordination the X axis from the robot is the opposite of the track. if I jog the track towards plus the X value of the robot becomes smaller. how can I fix this? Thanks!
  • Does the robot actually move (when you jog the track), or is it just the value that changes?
  • You will need to rotate the base frame of the robot to match the base frame of the track.
