Write to an FTP server
svoldgaard
Yes -- writing to a FTP server uses the same commands as writing locally -- Open, Write, Close -- but the FTP server location is first setup in the SIO config file (Configuration > Communication in RobotStudio).0
Okay. found what I need basically, but something is still wrong. Can I use it in an virtual controller?0
I can't get a known good FTP configuration to work on a virtual controller.
