Interpolate Path with MoveAbsJ in the path
A colleague of mine discovered a bug that if he has a moveAbsJ in his path before the points he wants to path interpolate, it ends up corrupting the moveAbsJ points in the station and says "Data declaration 'absJPoint'(name of AbsJPoints) is not supported". The AbsJ points are not within the points being interpolated. If they come after the section that you are interpolating, they are fine and everything works. This bug was found in 5.61.02 and verified that it still happens in 6.01.01.
