Unabled to add new task
I'm trying to add a new task, but the button is disabled. My station has 623-1 Multitasking installed.
I'm using RobotStudio 6.01
Can anyone help me?
Thanks
Can anyone help me?
Thanks
Is it a real or a virtual system and what RobotWare are you running?
Per Svensson
Consat Engineering0 -
If you added Multitasking after the system was created did you I start the system (make sure you save any RAPID programs first)?
I have found the problem.
I have set up the station a bit wrong. 0
- 38 AppStudio
