Using tables in WWServer [WebWare Server]
a customer likes to write data from one robot to a custom database?
Is it possible to use two tables from one robot? How do I have to switch between the tables in my RAPID code.
  • Hello Kevin,
    Yes it is possible to write to multiple tables. To do so, simply adjust the SCWrite command to direct the data to the correct table. For example:
    SCWrite MyTableRec;
    SCWrite MyTable1Rec;
    I have attached a modified version of the sample custom db module contained in the WebWare Server User's Guide that creates and writes to two tables.
    Note: this sample also requires WebWare.sys to be installed on the controller.
    rob.zip
    Webware.zip
    RussD38068,7680208333
    Russell Drown
