How do I set up multimove in Robotstudio?
I want to control three robots which will work independent of each other using a single controller in robotstudio. Can anyone please help me with suggestions of how I can do that?
  • Hi,
    The easiest way is to create a empty solution, add the three robots (and position them in the correct places) from the  ABB library then from the robot system button select from layout - follow the prompts taking the appropriate RobotWare options when asked.
    Regards
    Graeme
  • Thank you Graeme. That helped!
    Regards
    Yandisa
