Profinet & LAN connection
Rookie
With an IRC5 ( 6.0101) I am running into difficulties with the profinet and lan connection. The profinet connection has IP 192.168.122.2, and i want to give the WAN 192.168.122.3. However, the IRC comes up with a error as the 2 adresses overlap. Afcourse i do understand this problem, but how to fix this? I had the plan to use a EWON for remote support on the PLC and the controller, but that seems to be hard. Any ideas?
Thanks.
I have the same problem, and I want to do the same, use an EWON and the PC Interface.
Un saludo, kind regards,
Daniel Aguilar
Automation Engineering
Please, UP. I have the same problem. LAN Address 192.168.250.123, and WAN 192.168.250.146
Daniel Aguilar
- 37 AppStudio
