How to edit existing screenmaker project?
sikilde
in ScreenMaker
Hello!
I have some issues when I try to edit a screenmaker project which is already added to the FP.
When I deploy the change to the FP, the change does not seem to appear. Even after restarting the controller, the changes are not there..
Does anyone have a solution to this problem?
Kind regards,
Simen Kilde
Kind regards,
Simen Kilde
Hello, when you deploy some dll files are created in the HOMe directory of your controller. You can try to delete these dll and deploy to recreate them and see if your changes appear.
Hello!Pavel Riabichev said:Hello, when you deploy some dll files are created in the HOMe directory of your controller. You can try to delete these dll and deploy to recreate them and see if your changes appear.
I tried that, didn't help.
We figured out that by restarting the FP with the "restart" button on the back side of FP, your last deployment is loaded and the changes appear.1
- 40 AppStudio
