RS 6.02 Compatibility with Painting PowerPac 6.0
Neily03
Just installed RS 6.02 and it doesn't appear to be compatible with the current Painting PowerPac version 6.0, the powerpac won't start properly.
There's no mention of this issue in the release notes......
Hello Neily,
Painting PowerPac 6.0 is not compatible with RobotStudio 6.02. There shall be a 6.02 version of PowerPac available in Dec 2015.
Thanks,
Sudarshan0 -
Oh..... that's frustrating. Would have been nice to put something in the release notes about but luckily I've not saved any of my stations in 6.02 or I would have been screwed and had to rebuild them in 6.01
RS 6.02 automatically converts the conveyor systems to the new format, but if you are dependent on Painting PowerPac, I would suggest you to wait until the release.0
Any new on Painting PowerPac 6.02?
Also I've tried to run my stations from 6.01 in 6.02 but can't get conveyor tracking to work..... is there some sort of guide to converting the station so it just works?
Any news on when the Painting Powerpac 6.02 will be released?
- 858 RAPID Programming
