rotate X and Z 30 degrees counterclockwise
hello
i want to rotate coordinate system of tool 30 degrees
clockwise i know that we must calculate q1 and q2,q3,q4 using matrix method
when i did rotate 90 degrees it work good because i think cosinus(90)=0 and cosinus(0)=1 . but when i use angles like 30 or 45 it doesn't work for me any one can help and explain for me good and practice method
Regads
clockwise i know that we must calculate q1 and q2,q3,q4 using matrix method when i did rotate 90 degrees it work good because i think cosinus(90)=0 and cosinus(0)=1 . but when i use angles like 30 or 45 it doesn't work for me any one can help and explain for me good and practice method
Regads
There is a Quaternion convertor available for download from the RobotStudio web site:
http://www.abb.com/product/ap/seitp327/5dd4fbc7afcb82d2c12579ad0054401d.aspx
Regards
Graeme
Thanks Mr Graeme for your helping
i'll try it
Best Regards
Amar0 -
tool.tframe := PoseMult(tool.tframe,[[0,0,0],OrientZYX(-30,0,-30)]);
BR,
blind3rrBenteler Maschinenbau CZ1
- 38 AppStudio
