SearchL
TuomasL
i am a beginner, so excuse me
My robot has to search for edge with SearchL. If search did not get any match, It should try the search 3 times again. How should i build the syntax right?
Tuomas
Tuomas
MODULE mSearchExample
! tool and wobj data
TASK PERS tooldata tGripper1:=[TRUE,[[-98.8713,1.66235,131.444],[0.958572,-6.3433E-05,0.284642,-0.0108527]],[2,[0,0,50],[1,0,0,0],0,0,0]];
TASK PERS wobjdata wobjPaper1:=[FALSE,TRUE,"",[[842.843,389.57,8.88436],[0.0132869,-0.00221957,-0.0038117,0.999902]],[[0,0,0],[1,0,0,0]]];
! home and service positions
CONST jointtarget pHome:=[[0,0,0,0,60,0],[0,9E9,9E9,9E9,9E9,9E9]];
CONST jointtarget pService:=[[53.3131,32.8006,36.608,-90.2556,25.1677,139.011],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
! speed data
VAR speeddata vIntermid:=[250,30,200,15];
VAR speeddata vDispense:=[50,30,200,15];
! search positions
CONST jointtarget jSearch_Start:=[[19.0408,41.392,14.4539,-65.2267,13.6518,84.7809],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
CONST robtarget pSearch_End:=[[139.37,943.08,188.16],[0.0127536,-0.999531,0.0155706,-0.0230594],[-1,0,-1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
PERS robtarget pSearch_Found:=[[152.064,466.067,184.558],[0.0127333,-0.999531,0.0155973,-0.0230583],[-1,0,-1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
! search error and search delta (to be used elsewhere)
VAR num nErrorCounter;
VAR num nFKey;
PERS num nSearch_Delta:=-33.933;
! temp signals, to be replaced with real signals
VAR signaldi di5_Trigger;
VAR signaldo do9_Light;
PROC rSearch()
! check the eye before search attempt(s)
WHILE di5_Trigger=1 DO
ErrLog 4800,"SEARCH EYE ERROR","Example Search photoeye is blocked","before the search.","Clean photoeye and press the Play","button to continue.";
Stop;
ENDWHILE
! search
MoveAbsJ jSearch_Start\NoEOffs,vIntermid,fine,tGripper1\WObj:=wobjPaper1;
SearchL\Stop,di5_Trigger,pSearch_Found,pSearch_End,vDispense,tGripper1\WObj:=wobjPaper1;
! search successful, use search data to do/calculate something
Clear nErrorCounter;
PulseDO\PLength:=3.0,do9_Light;
nSearch_Delta:=pSearch_Found.trans.y-500;
MoveAbsJ jSearch_Start\NoEOffs,vIntermid,z50,tGripper1\WObj:=wobjPaper1;
ERROR
IF ERRNO=ERR_WHLSEARCH THEN
IF nErrorCounter<2 THEN
! error and redo search
Incr nErrorCounter;
ErrLog 4800,"SEARCH ERROR "+NumToStr(nErrorCounter,0),"The example search "+NumToStr(nErrorCounter,0)+" errored.","","Trying example search again.","";
RETRY;
ELSE
! give-up on search
MoveAbsJ pService,vIntermid,fine,tGripper1,\WObj:=wobjPaper1;
Incr nErrorCounter;
ErrLog 4800,"SEARCH ERROR "+NumToStr(nErrorCounter,0),"The example search "+NumToStr(nErrorCounter,0)+" errored.","Examine tool and photoeye and press","the Play button to move Home.","";
Stop;
MoveAbsJ pHome\NoEOffs,vIntermid,fine,tGripper1\WObj:=wobjPaper1;
EXIT;
ENDIF
ENDIF
ENDMODULE
