Best way to import Geometry (converted from CATIA / .cgrs)
c63amg
I have a complex CATIA assembly with numerous parts. I am trying different export methods to maintain the most accuracy as well as the most efficient file size.
So far I have tried to convert each of the .cgr(parts) as .SAT's. The assembly imported into RS fine, but the file size of the station jumped to 1.3gb and has a lot of lag.
Any ideas?
Thanks
Any ideas?
Thanks
What if you remove the cad geometry, right click on the part and select modify and remove cad geometryPer Svensson
Consat Engineering1 -
