Solved: Virtual signals in RobotStudio 6.02
ko414du4
ko414du4
edited February 2016 in RobotStudio
How do you create a virtual signal in RobotStudio 6.02? Earlier in RS 15.15 you can create a virtual bus and a virtual unit, and then a virtual signal. But in RS 6.02 there's only "Industrial Network" and the virtual unit/bus is greyed out. Help please..
Many thanks.
Post edited by ko414du4 on
  • With RW 6.x you don't need the virtual bus & unit, you just choose <none> for Device when creating the signals.
    Regards,
    Johannes
    Johannes Weiman
    Software Engineer
    RobotStudio Team, ABB Robotics
  • Thanks JWeiman!
