Rotate table mechanism
St4rk
Hello, I want build SC_Rotate Table. When robot put down ''Part_6'' then table should rotate about 90° and then robot put down next part on table. This should be do until the first part will be in Line Sensor Dettach, where table send signal and robot take part. But I don't know how Attach and Dettach ''part'' and rotate with this part. I don't know why I can't upload station here so I put link http://uloz.to/xY9yr4tn/table-rspag
Thank you
Thank you
Take a look at the solar simulation P&G station supplied with RS. Located in your documents flolder\RobotStudio\StationsPer Svensson
Consat Engineering0 -
I look but it is complicated and I don't understand it. I think I need simplier SmartComponent than in solar station.0
