Ethernet/IP slave Schneider electric NIC2212
I need help configuring a slave input / output schneider - electric stbnic 2212.
I get the error message " invalid segment in path" .
Enclosed my setup .
I specified that my other slave cognex DataMan 260s is ok .
Thank you in advance for your help.
( sorry for my English)
Ben
Best Answer
  • Hello Ben
    Did you get the dataman working?
    I have an upcoming project where the robot uses dataman 260 reader to read product serial numbers. I'm a little bit confused about the communication between dataman 260 and IRC5 controller. Is it possible that you could share any information with me about the communication? For example the IO mapping or is it possible to do it throe socket communication?
    Rickard
