QStop event routine
Hello all,
Can I use QStop event routine to set a flag when a collision is detected? My system has a collision detection option but not multitask, so setting up a special task for this purpose is not an option.
Thank you for all the comments.
Best Answer
  • Rookie said:
    Hi, afcourse you can do this. When the robots stops, the event is executed, with your bool.
    Jeroen
    Thanks for confirming this Jaroen!
