Not possible to add inputs/outputs in RobotStudio 6.02.01
When adding a virtual input and/or output, the following error appears. What can might be the cause of this?
Opening a station with inputs/outputs works with no problems.
Tested with both 32-bit and 64-bits options.
Hugo Costelha
Hugo Costelha
We have seen the same problem with Robotstudio 6.03. We needed do create a new system and a new station to solve the problem.0
