Moving Axis without moving the tool
Username
Hello.
I'm working on an project for open day of my school, where our ABBs should move some wodden blocks around. For schow reasons I'd need to move the robots axes without changing the position of the tool.
As I don't know how I could do this, I'm asking if you have any ideas.
Look-up how Tool Center Points (TCP) work.
Thank you for your answer. I know how they work, why?0
It sound like you want to changed the orientation of the tool but keep the position. In that case you should take a look at RelTool where you can change the orientation around x,y,z but keep the positionPer Svensson
Consat Engineering0 -
Thank You.
