System from Layout does not wotk with MTD in RobotStudio 6.02.01
Add a robot (e.g. IRB1600_6_145), add a mechanical unit (e.g. MTD 250), selectec Robot System From Layout an you get the following errors:
RobotStudio .NET exception: Could not find a part of the path 'C:\Users\hugoc\AppData\Local\ABB Industrial IT\Robotics IT\RobotWare\RobotWare_6.02.1029\utility\GearUnits-TypeA\MTD250-TYPEA (3HAC049763-001)\DM1'. ============================================ Base exception: DirectoryNotFoundException Could not find a part of the path 'C:\Users\hugoc\AppData\Local\ABB Industrial IT\Robotics IT\RobotWare\RobotWare_6.02.1029\utility\GearUnits-TypeA\MTD250-TYPEA (3HAC049763-001)\DM1'. at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileSystemEnumerableIterator`1.CommonInit() at System.IO.FileSystemEnumerableIterator`1..ctor(String path, String originalUserPath, String searchPattern, SearchOption searchOption, SearchResultHandler`1 resultHandler, Boolean checkHost) at System.IO.Directory.EnumerateFiles(String path) at RobotStudio.Services.Systems.TemplateSystems.ConfigurationFile.ResolveAndCreate(String name, Int32 number, RobotWareInfo rw) at System.Linq.Enumerable.WhereSelectEnumerableIterator`2.MoveNext() at System.Collections.Generic.List`1.InsertRange(Int32 index, IEnumerable`1 collection) at ABBInternal.Controller.SystemFromLayout.SystemBuilder.VirtualSystemBuilderGandalf.<PrepareSystemAsync>d__d.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at ABBInternal.Controller.SystemFromLayout.SystemFromLayoutWizard.<BuildSystemAsync>d__10.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at ABBInternal.Controller.SystemFromLayout.SystemFromLayoutWizard.<InitializeOptionPage>d__9.MoveNext()
- 38 AppStudio
