MultiMove master/slave program. Slave following master's movement.
MrRoger
Hello!
I'm just starting my journey with MultiMove and after reading MultiMove manual I still don't have an idea how to accomplish the task which was given to me.
So I have two robots- one next to another, with screens in front of each of them. They are both identical.
The task is to make a path for the first robot (master), so that it writes a word on a screen, for example "Hello!".
The second robot (slave) should follow only the movement of the first one, which has to be identical. In the result, slave should also write the same word on it's screen.
The tip I have, is that I should add some workobjects, which configurations is essential to finish that task.
I've read something about coordinated movement in the manual- I guess that I should use that. But how do I do that?
Thank you very much for any help!
Solved by myself!
Please, how you solved it ? Thanks0
