Move Systems
Hello!
I got an problem with systems in RobotStudio.
When i move a system from my personal documents folder to an other folder the system cant start anymore.
There ist the first message that the system cant be found at the old place. Now you can select the new place but when
RobotStudio try to start the system, there comes an timeout message.
"Exception: C0040403 : No response from controller. Netscan timeout [2]    13.04.2016 13:29:18    Allgemein    "
Can someone help me.
  • You need to select reset system (I-start) when you have changed the location. Right click on the controller and select restart/reset system . BE AWARE of that this will blow your rapid code and system parameters. So you need to have a backup to get back. You could probably find your rapid code in the system directory /INTERNAL/RAPID/PRGx/ and the files have no extension but are plain text files
    Per Svensson
    Consat Engineering
