Stop --> Reset/Start using interrupt and trap
MattM
Hi, I'm programming a robot to serve 6 flavours of espresso but I need help with a stop-reset/start function.
What I want is:
- Stop = the robot stops where it is, even if it's on its way to a position.
- Start or Reset
- Start = if I press Start without a Reset, I just want the robot to keep doing what it was doing when the stopbutton was pressed. But if Reset has been pressed then i want it to start at the top of the program - ready for a new order.
- Reset = What the robot does depends on what it was doing, for example if it was holding a cup of espresso when Stop --> Reset was ressed I want it to put down the cup and move to home position.
I have an idea but im not sure if it would work (di1=stop di2=start di3=reset)
VAR intnum intno1;
CONNECT intno1 WITH Stop;
ISignalDI di1,1,intno1;
TRAP Stop ()
StopMove;
WaitUntil (di2+di3=1);
IF DI2,1 THEN
StartMove;
ELSEIF DI3,1 THEN
Clearpath
... (what ever I want it to do when i reset)
PPToMain
ENDIF
ENDTRAP
Would something like this work? Is there a better way? Please help.
Thanks in advance.
What I want is:
- Start or Reset
VAR intnum intno1;
TRAP Stop ()
StopMove;
IF DI2,1 THEN
StartMove;
ELSEIF DI3,1 THEN
Clearpath
PPToMain
ENDIF
ENDTRAP
Thanks in advance.
It would work but using a trap routine but it adds additional hassle you shouldn't need.
Stop = system input "Stop"
Start = system input "Start"
Reset = system input "StartAtMain"
At the top of main,
IF (sensor to know if it already has a cup) THEN
Move to finish delivery of that cup and go to home position;
ELSE
Move to home position an get ready for a selection;
ENDIF
WaitUntil Selection > 0;
IF Selection = 1 THEN
Move to get and deliver Flavor 1;
ELSEIF Selection = 2
Move to get and deliver Flavor 2;
ELSEIF...
ENDIF
1 -
Yeah that makes sense. Didn't think of system inputs, it sure makes it simpler. Thanks for the help!0
Hello. I'm working on a very similar problem. I use a trap routine to stop movement when a collision fault occurs.There is a digital output always set on in the process, i cant reset the DO in the interrupt, tried different ways using cross connection and system outputs associated to states and dont get it.The example below, thanks.RETURN
MODULE ...
VAR intnum supmov;
VAR intnum supstop;
PROC ...( )
CONNECT supmov WITH supervision;
CONNECT supstop WITH reset_output;
ISignalDO, MotSupTrigg, 1, supmov;
ISignalDO, stop_program, 1, supstop; ! Use a "stop_program" system output with Motors On state attached to a virtual DO
Loop
TRAP supervision
RESET DO_PROCESS
RETURN
TRAP reset output
RESET DO_PROCESS
ENDTRAP
- 38 AppStudio
